It is currently Wed Jul 09, 2025 3:26 pm
Post new topic Reply to topic  [ 33 posts ]  Go to page Previous  1, 2
PostPosted: Thu Sep 14, 2006 8:41 am
Thanks Michael
Yes, that's what i had done with the previous kind of finish, i had sprayed it on and scraped the area of the bridge after but didn't like the way that finish looked
PostPosted: Thu Sep 14, 2006 8:47 am
Ok what ever you do do not put masking tape on the bridge. the adhesive will be drawn out of the tape and contaminate the muneca both inner and outer pads, and make a mess.
Also you will find that it is near impossibel to spirit off on the top as well as you would like. in this case and in this case only spit off across grain wher needed to get up agist the bridge. pinch shape the muneca into a point so that you can get tight to the bridge without spreading alcohol and shellac on to the bridge.MichaelP38974.7440856481
PostPosted: Thu Sep 14, 2006 8:58 am
Michael, fortunately, that is exactly how i spirited off the top last night 2 hours after the 2nd body session, i also will listen and not put any masking tape on the bridge, thanks!
PostPosted: Thu Sep 14, 2006 10:56 am
No Hesh I don't on French polish applications and here is why. The hand rubbing of body sessions and spiriting off causes the adhesive on the tape to migrate out a congeal with the shellac. what a mess! For this reason I don't bother with locating the bridge till after the finish is complete. So I end up scraping the finish off under the bridge and fretboard extension.MichaelP38974.8319560185
PostPosted: Thu Sep 14, 2006 12:39 pm
[QUOTE=MichaelP] The hand rubbing of body sessions and spiriting off causes the adhesive on the tape to migrate out a congeal with the shellac.[/QUOTE]
Oh, yeah, I can testify to this!!!
PostPosted: Thu Sep 14, 2006 6:50 pm
[quote=MichaelP]So I end up scraping the finish off under the bridge and fretboard extension.[/quote]
   That's always the way I've seen it done, but never new why. Now it makes sense!
Billy Dean
PostPosted: Thu Sep 14, 2006 10:29 pm
Thanks again Michael, very precious tips that i saved to file!
